Teensy-based CANbus gauge (and more)
xrattiracer
Post by xrattiracer »
Since my project has diverged quite a bit from the original Arduino based one in http://www.msextra.com/forums/viewtopic ... 67&t=52539 I figured it was a good idea to make a separate thread. You can read that thread for some background on the project.
The main differences are that it now uses a Teensy 3.1 instead of an arduino, and it sends data back to the MS as well (currently the data is GPS, accelerometer, and time).
Code is at https://github.com/merkur2k/MSCan_Gauge/tree/teensy which was forked from bittertech's code.
Hardware work in progress:
pit_celica
Re: Teensy-based CANbus gauge (and more)
Post by pit_celica »
On the top right of your breadboard, the PCB with the twisted wires going in it, is it your CAN hardware interface? Did you buy it as is or did you build it?
I'm asking because I'm looking for an alternative on one of my Arduino project instead of the usual CAN shield that is quite bulky for what it is.
Nice project by the way!
Sam
xrattiracer
yes, that is the CAN interface, but it is just the transceiver portion since the teensy has a controller built in. In other words it will not work (by itself) with an arduino since the arduino needs both a controller and a transceiver.
xrattiracer
To add a little more, I purchased the CAN transceiver as is.
And in the end, a teensy + can transceiver is actually a lot cheaper than an arduino + can shield. not to mention being physically smaller, and MUCH easier to program.
xrattiracer
I've got a plan to fit all of this within the space of a standard 2 1/16" gauge housing. Just sent off the oder for a custom PCB that will function as a carrier for all the various modules. The gauge body will be 3d printed.
acab
Post by acab »
I love you man!
Add 4 EGT sensors please and much custom input\outputs :D!
Zaphod
Post by Zaphod »
Keep up the good work, there are more than enough customers for sure!
fun is not a straight line
Sven
Suprazz
Post by Suprazz »
nice project and nice job!
xrattiracer
custom PCBs arrived, but i found out my pin headers are not compatible with each other so now i am waiting for different ones to arrive. but its enough to have a good guestimate on physical layout, so i can start working on the gauge housing 3d model. its going to end up deeper than i wanted (around 70mm) but i am hoping that will still work with most gauge pods.
As happens with prototypes, i also completely neglected to include a header for the rotary encoder!
dsmcrzy
Post by dsmcrzy »
Wow!! Excited to see the progress and final product!
xrattiracer
ok, final mockup shot:
and to show that it does indeed send stuff back to the ms:
now that i know the final dimensions of everything, i can finish up the housing model and get it printed tomorrow hopefully.
Zaphod
Post by Zaphod »
So exciting! Nice work!
Sven
xrattiracer
first housing prototype:
Zaphod
Post by Zaphod »
I can't wait to get my hands on one or two (I guess you can even use two of them with one MS?) of these things!
How do you program what values/sensors you see on the gauge?
Is the long breakout-board extension to the back necessary, or can you keep that a bit shorter?
Thanks!
Sven
xrattiracer
everything for the display is set in code. not hard to change if you know how to code, but otherwise there is no mechanism.
The rear connector will only protrude as fas as necessary to be able to hook up wires in the final version. the housing itself is far deeper than i want it to be though, still trying to figure out how to reduce that. i am not sure that most gauge pods will have the room for 75mm depth...
dsmcrzy
Post by dsmcrzy »
Wow that looks great!! I will have to read into the teensey forums and see what I can cook up. I would like to make a built in display sorta like what you did but have it be bigger and able to display more.
Great job though!! And that 3D printer looks like it has pretty good resolution if it's right out of the machine.
xrattiracer
i am going to eventually dig into doing something with a 5" or 7" touchscreen running on a raspberry pi or similar, with a qt/qml app as a dash.
and yes thats right off the printer.
xrattiracer
been awhile since i posted but not a whole lot new to report yet. I have a new prototype that has a mounting depth of about 45mm, which makes it nearly the same as most existing gauges. Currently waiting for a new revision of the PCB to arrive from the fab.
Raymond_B
Post by Raymond_B »
What 3D printer are you using?
http://www.buildpics.org/
xrattiracer
it is a prusa mendel i2 kit that i got from makergear.
