Hi all,
I've been playing around with sending ADC sensor data to my Microsquirt over the CAN bus from an Arduino. I believe I have the data flowing correctly, the Arduino responds to the requests and if I set the baro or O2 sensors to "Remote ADC x" they react to different values. However, I can't seem to figure out what the scaling is.
My immediate thought was that 0x0000 would be like "0V" and 0xffff "5V". However, the baro sensor seems to scale as one count being 0.01kPa regardless of how the calibration is set. And the lambda readout is completely nuts, flipping all over the place.
Is the expected scaling for the different sensors documented anywhere?
Thanks,
/Patrik
CAN ADC format
Re: CAN ADC format
Sensor ADC inputs are assumed to be 10-bit values. The reason for this is that the MS2 ADC inputs are 10-bit values (0-1023). And the calibration is also working on that assumption.
Re: CAN ADC format
Aaaah!
Now the baro numbers make perfect sense, thanks! The only funny thing is that the reading apparently doesn't saturate at 1023, it keeps on going if you send a higher number.
However, I can't find the O2 sensor calibration anywhere. I was confused about this before, too. Surely it must exist somewhere?
Re: CAN ADC format
Unlock calibration and calibrate AFR table in the tools menu.
Re: CAN ADC format
Ah, perfect! The "AFR table" didn't sound like a sensor calculation. so I never checked that option out.
Thanks! All is good now.
Re: CAN ADC format
I'm really pleased at how easy it was to get this working, actually. I'm using an Arduino Pro Mini, a MCP2515 can controller and a MCP 2551 transceiver. This is the same hardware that's on the Arduino can-bus shield, only the bare components are $3.50 as opposed to the $40 for the shield. And apart from 2 resistors, that's all that was needed -- you can clock the 2515 off the Arduino clock output, so you don't really need a separate crystal, and I'm not interested in the other hardware on the shield. Total hardware cost, something like $12! I'll probably spend more money than that on finding a waterproof case and connector...
Re: CAN ADC format
hi, I know this topic is old, but it matches what I'm trying to do too. I found mscan library created by lutorm, I'd like to use it but I didn't find any documentation or example files, could anyone help?
