Posted this also in TS as I'm not sure in which board this is placed best. If this is wrong, please remove.
Tried to install my JBPERF CAN device and got the following error :
Jean proposed to post it out here as well.
IOX can device installation into TS fails.
Re: IOX can device installation into TS fails.
Hi Yves,
From your screenshot, it look like you try to reach device "Corvette MS3" witch should be you ECU and try to use it with the TinyIOx ini. If'what I guess is right, you have a TunerStudio configuration fault. It's look'like you have inverted ms3.ini with tinyiox.ini in your project properties.
Regards,
Manu
Regards,
Manu
Thanks Manu, however after suggestion of Jean, I reflashed firmware with the new version. This seemed to solve it. However I might need to do it again with a beta version as the 1.4 version I used seems to have some CAN issues.
