Can bus add on board
Alfagta
Post by Alfagta »
Hello,
here you can see then can bus add on board which i have made.
It has a few i/o and reprot them via can bus to the MS2 or MS3.
The board is in a nice housing and very robust housing.
It has:
4x 0-5V Sensor Input's (or NTC with internal bias)
8x Thermocouple Inputs's k-type
4x NPN mosfet output with separeted gnd (3A)
2x Input (Digital or Frequency )
Also it is possible to attache an LCD display.
You can choose from a list of about 20 diffrent variables which can be displayed on it.
The configuartion off the board is made with TunerStudio.
So now here are the pictures:
Alfa 156 GTA
Alfa 75 Race Car MS III -- alway latest FW
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Test MS II --always latest FW
Tunerstudio V2.6.11 Registered
MegaLog Viewer V3.4.04 Registered
dontz125
Re: Ca bus add on board
Post by dontz125 »
Interesting. I assume the pin headers etc are for function selection? Do you have options for bias resistors for temperature sensors?
I'm a little surprised you picked such a waterproof case, then poked holes in it for wires. Even with grommets, the sealing won't be the same. Would it not have been better to use the 48-pin header, and bring the TC wires in that way?
Alfagta
Post by Alfagta »
Hello,
no funktion selection is made with tuner studio.
2 ways to do it, can passthrough or direkt via rs232.
2 Pinheaders for programming and the other one is for the lcd display.
Yes there are also bias resistors to use temperature sensors at the 0-5v inputs.
I choose the housing because its robust.
It's not designed to be fully water proof.
BR
Alfa 156 GTA
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
grom_e30
Re: Can bus add on board
Post by grom_e30 »
so are you going to be selling these?
Alfagta
Post by Alfagta »
grom_e30 wrote:so are you going to be selling these?
If you want such device why not
Alfa 156 GTA
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Alfagta
Post by Alfagta »
Here are pictures from the stand alone display...
Alfa 156 GTA
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
wes kiser
Post by wes kiser »
What is your target price? This actually looks more finished/ready to go for the casual user than most of these projects are.
Alfagta
Post by Alfagta »
Hello,
yes it's more or less finished.
There are a hand full in use already.
But i add some new features to the io and display board from time to time.
Target for io board is 170$ and for the display it is 100$.
BR
Alfa 156 GTA
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
jasaircraft
Post by jasaircraft »
do you have a website, where can the purchase be done? i want to add k types to a 4 and 6 cyl in the near future
