More than a CAN gauge!
Postby Suprazz » Sun Aug 07, 2016 6:03 pm
*** The gauge is now available ***
Latest pictures, info and order link: http://perfecttuning.pswebstore.com/en/ ... gauge.html
I would like to present you a new project I was working on for the last months. This will be a commercial product available in few weeks!
It's a new 52 mm (base, 66 mm overall), 1.7" Color, 24 multicolor LED, CAN bus, 3x analog inputs and more, universal gauge that will be available on the market very soon (and I'll take pre-orders)
The gauge fit in a 52 mm gauge pod and the overall diameter is 66 mm.
Here is the pictures of the PROTOTYPES version 1 and 2. The difference between the prototype and new version are:
- The new version will use a 1.7" OLED instead of a 1.5" OLED.
- The new version is slimmer
- New version doesnt have a connector on the back. There is wires going out and the connector will be inline for a cleaner look when installing without gage pod.
This is what the prototype version #1 look like:
And prototype version 2 and final version will look like:
All gauges will be made from billet aluminum and will be anodized black (or other colors on demand) for a very clean finish.
The gauge will be able to request data on the MS2 and MS3 over CAN bus. I plan to support other ECU later and OBDII too.
It will also include 3x protected generic 0-5v inputs. This gauge can be used without any standalone to display values of sensors connected to it.
Here is a list of sensors that will be compatible will this gauge:
- GM 3 bar MAP
- 150 PSI Oil/fuel sensor
- Temperature sensors like GM CLT, GM IAT.
- AFR sensors (Like the 14point7 wideband controller or the PerfectTuning that is using the Spartan 2 controller from 14point7).
- Flex fuel sensor (later)
- And more on request.
There is an ambient light sensor to automatically adjust display and led brightness
There is a digital input too.
And 1 pwm output to eventually use it as a boost controller.
There is 2 (hidden) buttons on each side to switch between screens and to configure the gauge.
The gauge is a Wifi hotspot so it's possible to configure it with your cellphone or laptop for the advanced configuration menus without installing any software.
There is actually few nice looking screens displaying multiple values at the same time.
The colors are configurable.
It can also be used as a shift Light.
I plan to also add configurable alarms (flashing (full led) with actual value to warn you).
The final retail price should be around 249USD when it will be released to market.
If you have any suggestions, other ideas or comment, please let me know!
Thanks!
Suprazz
Re: More than a CAN gauge!
Postby nathaninwa » Sun Aug 07, 2016 6:18 pm
Uhm, how cool is that. Nice work for sure and should look nice in the hole I'll have open soon :D
Volvo 940, 2jzgte, MS3Pro, 815/692 @ 27psi.
240z, LS3 MS3pro/micro I/O 8.28@173
86 454/4l80e, ms3pro/micro. Tow rig
nathaninwa
Postby Broke4speed » Tue Aug 09, 2016 6:23 am
That's perfect! :D
1984 Volvo 244
DIY MS1 v2.2
NA for now.
Broke4speed
Postby mrpham » Sat Aug 13, 2016 7:35 am
Interested in some production photos :)
mrpham
Postby Zaphod » Mon Aug 15, 2016 12:26 am
+1
fun is not a straight line
Sven
Zaphod
Postby Suprazz » Wed Aug 31, 2016 8:09 pm
Here is an update.
There was a big error on the version 2 so I changed few things and sent version 3 in production.
Here is a picture of the version 2 pcb.
I'm working on many things and I'll have more pictures soon!
Suprazz
Postby nathaninwa » Wed Aug 31, 2016 8:40 pm
Very cool
nathaninwa
Postby Zaphod » Thu Sep 01, 2016 6:41 am
Yeah baby... keep us updated! Very nice!
Sven
Zaphod
Postby Sweeperstang » Wed Sep 28, 2016 2:30 pm
That looks cool.
Sweeperstang
Postby Suprazz » Fri Oct 07, 2016 8:01 am
Teaser shot of the final version with new billet aluminium enclosure without anodization... Final version will be anodized black.
Sticker is missing and cables on the back.
Suprazz
Postby nathaninwa » Fri Oct 07, 2016 8:53 am
I'm liking this setup. Will fit perfect in the dash of my drag car front and center
nathaninwa
Postby Broke4speed » Fri Oct 07, 2016 9:22 am
I REALLY like this :).
1984 Volvo 244
DIY MS1 v2.2
NA for now.
Broke4speed
Postby Zaphod » Fri Oct 07, 2016 9:28 am
Do want!
Sven
Zaphod
Postby Suprazz » Tue Oct 25, 2016 6:45 pm
Enclosure with black anodization. Pretty much final product!
Suprazz
Postby nathaninwa » Tue Oct 25, 2016 7:00 pm
I do like the outcome
nathaninwa
Postby krisr » Wed Oct 26, 2016 1:58 am
Can the outer LEDS be programmed to act as a shift light or anything like that?
Sydney, Australia
1971 Holden Monaro HQ
krisr
Postby Suprazz » Wed Oct 26, 2016 4:23 am
Yes, ill create an alarm module so youll be able to make the whole ring blink in different colors to let you know that there is something wrong. Shiftlight will be done like this.
Video and more pictures comming soon!
Suprazz
Postby krisr » Wed Oct 26, 2016 4:26 am
Awesome!
Sydney, Australia
krisr
Postby Zaphod » Wed Oct 26, 2016 4:48 am
So rad! Any idea what the prices will be like?
Sven
Zaphod
Postby Suprazz » Wed Oct 26, 2016 5:17 pm
Around 250 USD for the gauge. I'll post all the info very soon
Suprazz
Next
Return to Expansion boards
