CAN BUS ADC Expansion Board
I'm making my own Arduino based EGT board that will read 6 EGT's and transmit them via CAN to my MS3. What I've understood so far is that I need to Enable ADC POLLING. Define CANID, Table and Offset of the ADC channels and start transmitting them from my microcontroller.
Is my understanding correct?
Re: CAN BUS ADC Expansion Board
Not quite.
You need to implement the send/receive Megasquirt-CAN protocol. This is documented in the Megasquirt CAN PDF from the Manuals page.
Hello,
take a look into this. http://www.msextra.com/forums/viewtopic ... 67&t=62735
That board has all you need and all in a solid case.
I don't know how you read the 6 egt sensors with the arduino but when you use
6 time max31855 that's expensive.
Best regards
Best regards
Alfa 156 GTA
Alfa 75 Race Car MS III -- alway latest FW
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Test MS II --always latest FW
Tunerstudio V2.6.11 Registered
MegaLog Viewer V3.4.04 Registered
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
The 1wire SPI TC amps actually are ~$4-6.
A 38150K or MAX31855 is pretty cheap by itself, on a custom board.
They only get expensive on the cute little prebuilt breakouts.
MS3 could talk to a string of them directly if the code existed, as it has SPI, only used for knock and clock modules at the moment.
I looked at this but I suck at programming.
That's exactly what I am planning to use. I want to daisy chain a bunch of those to my arduino and transmit the data by CAN to MS3. I'm already reading the dash info off the MS3 via CAN
Do you know the samle time for the 1 wire tc amps?
Alfa 156 GTA
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
looks like 1.2 hz at 12 bit, or 10 hz at 9 bit resolution.
Between that and the 700C/1290F temp limit they might be best used for CHT.
(There may be a way to extend the range, but its usually related to power voltage and these run on 3,3v... )
There may exist chips that run on 12v and still talk spi--- Not necessarily 1wire... full spi is capable of much faster transfers than 1 wire IIRC. haven't looked.
The settling time of a typical analog TC amp is ~40us, and the A/D conversion rate is a further variable, but 25-30hz is probably reasonable, double that is usable depending on the A/D setup.
For small changes it is likely faster, and you can of course read it faster, but it may not always tell you much.
You could of course build a very fast TC amp setup plugged into a scope or fast DAQ setup and a fine wire exposed tip EGT probe and see individual cylinders firing at 10K RPM, but not on a MS-anything.
I'd personally love to see MS3 being able to talk to a set of these and a set of 14point7.com WBO2 modules directly over spi and skip the CAN part, as all you'd need is possibly an SPI transciever/buffer if that.
I'm curious what the update rate is of something like a CAN-EGT is for comparison.
The MAX31850 has arround 75-100ms sample time according to the data sheet.
Alfa 156 GTA
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
