CAN-EGT .ini file
CAN-EGT .ini file
Postby prof315 » Wed Nov 16, 2016 4:27 am
Does anyone have a good copy of the CAN-EGT .ini? I'm trying to set one up with an MS3 and when I try to download it from DIYAutotune I get the full expanded text. If I save that as can-egt.ini and try to use it I get an error that says "firmware serial signature entry not found in ECU definition" and it locks up the project.
Linfert Performance: Come run up front
92 Corrado 2.0L ABA and Borg Warner EFR 6258 on MS3Pro.
94 Ranger 2.3 Twin Plug on MS2
Support the developers!
prof315
Re: CAN-EGT .ini file
Postby prof315 » Wed Nov 16, 2016 5:42 am
got it
prof315
Postby prof315 » Sat Apr 15, 2017 3:11 am
I'm attaching the file for anyone who needs it
You do not have the required permissions to view the files attached to this post.
prof315
Postby prof315 » Sat Apr 15, 2017 1:09 pm
And here is the MS3 .msq that is working with the CAN-EGT
prof315
Return to Expansion boards
