I'm working to get phase detection with the QuadraMap "cam signal" working, and after scoping the signal I just wanted to make sure I'm not mistaken: The cam signal is an edge detection signal, ie it makes a short high pulse when the #1 MAP drops below the set threshold, and not a comparator output, ie being high for the duration the #1 MAP is below the threshold? The wording had led me to believe the latter but the scope output shows pretty clearly it's the former.
Cheers,
/Patrik
QuadraMap cam signal question
Re: QuadraMap cam signal question
It's a pulse.
