TinyIOX pressure gauges
Postby hybrid » Thu Sep 14, 2017 7:10 am
I just got my TinyIOX and have fitted it to my MS2.
For now I just want to log some transmission pressures via two 0-5v sensors.
I have done the following:
- Enabled CAN polling on the MS2
CAN ID 4
Table 7
Table Offset 45
Set direction to 3 inputs (for now)
Remote port types are all single value
On the TinyIO config, I only enabled ADC with resolution set to 10 bits.
I have activated ADC channels 1 and 2.
Do I need to use the ADC grouping under CAN parameters for my setup?
Do not load someone elses tune and expect it to work for you!
hybrid
Re: TinyIOX pressure gauges
Postby racingmini_mtl » Thu Sep 14, 2017 10:15 am
For pressure sensors, you need to use the ADCs not the digital inputs. So disable the port polling on the MS2 and enable the CAN ADC 0-3 polling. You just need to change the default CAN ID to 4. Also remember that the ADC numbering is different on the MS2 and the TIOx; the MS2 starts at 0 while the TIOx starts at 1. So ADC channels 1 and 2 on the TIOx will be on 0 and 1 on the MS2.
racingmini_mtl
Postby hybrid » Thu Sep 14, 2017 4:02 pm
Thanks Jean.
The reason I asked about this is because when I enabled the ADC0-3 grouping option (MS2), ADC0 and ADC1 both seemed to move the same gauge.
But maybe this is a gauge config issue rather than anything else.
hybrid
Postby racingmini_mtl » Thu Sep 14, 2017 4:44 pm
It's hard to say without seeing your project. If you can't figure it out, post your project (not just the msq but the MS2 project that has the TIOx as a CAN device; you can create a project backup file in TS).
racingmini_mtl
Postby hybrid » Thu Sep 14, 2017 5:56 pm
Will do - I will have a bit more of a play around this afternoon when I get home and if still no good I will post the configs.
It may also be that I've got a solder bridge somewhere.
hybrid
Postby hybrid » Fri Sep 15, 2017 1:42 am
All good after changing those settings.
hybrid
Return to Expansion boards
