IObox 1.004 beta test
Postby jsmcortina » Fri Dec 01, 2017 2:48 pm
IObox firmware 1.004 is available for testing.
This release zip includes four distinct "s19" firmware files.
iobox1.s19 - implements IObox #1 functionality to connect to MS3, does not include "Megasquirt-CAN".
iobox2.s19 - implements IObox #2 functionality to connect to MS3, does not include "Megasquirt-CAN".
iobox3.s19 - implements IObox #3 functionality to connect to MS3, does not include "Megasquirt-CAN".
iobox-ms2.s19 - implements IObox #1 functionality and includes "Megasquirt CAN" to allow use with MS2.
The main IObox firmware has Megasquirt-CAN support removed and only uses standard 11bit CAN at 500kbps. This should allow the IObox to be used on a CAN alongside devices (such as AEM UEGO) that broadcast with 29bit headers that could interfere with the IObox with the Megasquirt-CAN enabled.
Another benefit of this is that the IObox will no longer show up in the CAN devices tab in TunerStudio.
This new version can be found here: http://www.msextra.com/downloads/dev/iobox/
Please test if you can to confirm it is still working as expected.
Re: IObox 1.004 beta test
Postby nathaninwa » Fri Dec 01, 2017 6:19 pm
Thankyou for releasing this James. I don't have anything currently to test it on, if I did I would only be able to run studfnin test mode. The engine is currently at the machine sho
If others can test this it would be appriciated
Volvo 940, 2jzgte, MS3Pro, 815/692 @ 27psi.
240z, LS3 MS3pro/micro I/O 8.28@173
86 454/4l80e, ms3pro/micro. Tow rig
nathaninwa
Postby brianj5600 » Sat Dec 16, 2017 11:15 am
Which IO box is this for?
1967 Mustang Coupe, 351w, S475 turbo, MS3.0 3x, c4, 8.8, ls coils, e85
brianj5600
Postby jsmcortina » Sat Dec 16, 2017 11:18 am
Return to Expansion boards
