IObox 1.004 beta test
IObox firmware 1.004 is available for testing.
This release zip includes four distinct "s19" firmware files.
iobox1.s19 - implements IObox #1 functionality to connect to MS3, does not include "Megasquirt-CAN".
iobox2.s19 - implements IObox #2 functionality to connect to MS3, does not include "Megasquirt-CAN".
iobox3.s19 - implements IObox #3 functionality to connect to MS3, does not include "Megasquirt-CAN".
iobox-ms2.s19 - implements IObox #1 functionality and includes "Megasquirt CAN" to allow use with MS2.
The main IObox firmware has Megasquirt-CAN support removed and only uses standard 11bit CAN at 500kbps. This should allow the IObox to be used on a CAN alongside devices (such as AEM UEGO) that broadcast with 29bit headers that could interfere with the IObox with the Megasquirt-CAN enabled.
Another benefit of this is that the IObox will no longer show up in the CAN devices tab in TunerStudio.
This new version can be found here: http://www.msextra.com/downloads/dev/iobox/
Please test if you can to confirm it is still working as expected.
Re: IObox 1.004 beta test
Thankyou for releasing this James. I don't have anything currently to test it on, if I did I would only be able to run studfnin test mode. The engine is currently at the machine sho
If others can test this it would be appriciated
Which IO box is this for?
1967 Mustang Coupe, 351w, S475 turbo, MS3.0 3x, c4, 8.8, ls coils, e85
Any feedback on this?
I'd like to promote it to 'stable'
I will give it a try once I get my transmission back in.
Something else I just remembered. For full support of 2nd and 3rd IOboxes, you need the (unreleased) MS3 beta also.
As there have been no reports of problems I have promoted this to 'release'.
