I make my own IO board with CAN communication.
Problem is, when I try to use digital ports. Setting CANOUT1-8 on CAN parameters.
Megasquirt send's CAN messages ok with remote CAN id, Table and offset. But when Output goes 0 --> 1 only one message is right value with "1" and next messages with "0". So the output is only very short time on but it shod be on all time.
Example:
Shift light is set to CANOUT1
RPM's go up, shift light shoud lit.
ID 19661496 (table 7, to_id 5, from_id 0, msg_type 0, offset 75) ext=1 len=1, data in byte[0] = 1000000 // This message is ok.
Next messages:
ID 19661496 (table 7, to_id 5, from_id 0, msg_type 0, offset 75) ext=1 len=1, data in byte[0] = 0000000 // wrong, should be same as above.
CAN communication problem CANOUT *SOLVED*
Re: CAN communication problem CANOUT
Can you post a screen shot of the settings for the shift light? You may have something wrong there.. ie. if RPM == 6000 then on, should be.. if RPM >= 6000 then on.
Ryan
What hardware are you working with, MS and IO board?
Ryan
Here the settings of CAN and shift light. I think at those are Ok.
I use Arduino leonardo board with MCP2512 CABbus-controller.
I'll upgrade the old mechanical gauge cluster to CANbus version.
Speedo, Odo and Rpm gauges use stepper motors and warning lights control through the CANbus.
http://www.hobbytronics.co.uk/arduino/leonardo-canbus
You do not have the required permissions to view the files attached to this post.
Attach an MSQ and a datalog of it happening.
EDIT: Also, for a straightforward dash, listening to the standard CAN broadcasts is typically easier.
I find the problem.
In MS3 setting I have CANIN and CANOUT active because I need both.
When MS3 reads CANIN with MSG_REQ message for CANIN. In the message a variable msg_req_data.values.varbyt say's how many bytes are the MSG_RSP reply message.
In my code it was the permanent 8 bytes. So I tested and verify this and when it send right amount of bytes it's working, I thing when reply is too long it's write zeros over the MS3 CANOUT registers.
Old code: txmsg.len = 8; and new working code is: txmsg.len = msg_req_data.values.varbyt; when assemble the reply CAN message.
-Mikko
-Mikko
