spandit wrote:Just got a load of bits from a BMW E28... (Bosch part numbers):
Injectors: 0 280 150 716
TPS: 0 280 120 301
Idle valve: 0 280 140 509
I also took the air meter (0 280 202 083) because it looked useful but I probably won't use it.
Can the rest be used with MS?
What year and model E28? Auto or manual? I ask because some of the later autos do have a TPS...
The 0-280-150-716 is a switch not a pot TPS.
MAF air meter isn't really used with MS. At least I don't use it. that air meter does contain the air temperature sensor, but
I usually just use a GM AX1 style sensor...
I think the idle valve may be usable, its a 3-wire pwm style valve. I didn't use one with my MS install, I used a simpler hot wire style.
What engine are you doing this to?
