LS style pencil coils
I got a look yesterday at a new GMC Terrain 3.0L and it uses pencil coils (DOHC motor) that are electrically identical to an LS coil! Even better it will fit a VW 20V head (and a bunch of others I'm sure) as a direct bolt in.
Support the developers!
Re: LS style pencil coils
Sounds good.
Part numbers? Photos?
I'll see what I can do.
I think I've seen these on ebay, they come in banks of 3, right?
No they are individual pencil style coils. AC Delco PN D515C, GM PN 12632479
well yeah but I mean when they are bolted to their mounting brackets, regular LSx coils are mounted in banks of 4 but they're still seperate coils
something like this?
http://cgi.ebay.com/AC-DELCO-IGNITION-C ... 19bfc28185
No they are individual and bolt seperately to the valve cover
Some additional Info on these coils: They are found on all 2010 GM 3.0L and 3.6L DOHC Motors and 08/09 3.6L Saturn VUEs.
that would be the beast
That's rad, you didn't measure any dims on it did you.. you know for me?
I only had my hands on one for about 20 minutes ( I was doing an oil change on a customer's Terrain) But I took one out and it is the same size as a VAG pencil COP coil. The bolt hole even lines up on a 20V head!Paul_VR6 wrote:That's rad, you didn't measure any dims on it did you.. you know for me?
i need like... 16 of these.
2020 BMW X3M - bm3 - stage1
1994 Supra - ms3pnp pro - j&s
just ordered one, will see if the standard ls1 connectors fit, and if these fit into my bmw's engine, supra's engine, and sentra's engine as far as length go.
hopefully these include the overdwell protection that's in the actual ls1 coils
The standard Delphi/Packard metripac connector doesn't fit. They use the new GT style connector. These guys should have them though: http://www.lsxtune.com/shop/index.php/cPath/109_130gurov wrote:just ordered one, will see if the standard ls1 connectors fit, and if these fit into my bmw's engine, supra's engine, and sentra's engine as far as length go.
And BTW newer (07 and up for sure) Ecotec 4 cylinders are using a shorter version of the same coil.
Newer Northstars are also using pencil coils now. Looks like the are somewhere in between the length of the V6 coil (longest) and Ecotec coil (shortest).
Sorry for the noob question, but...
So will MS drive these coils directly? No need for an ignitor box?
Yep, you'll just need to set up a 5 volt logic level spark output for them.
I believe the 07-08 suzuki XL7 with the 3.6l uses the same coil as that terrain . I used to work for suzuki so I am pretty familiar with that coil.Too bad I didnt scrounge any of them . I do have 4 2009 ecotec coils though but they are a little short for my nissan though...bummer.
Ricky-
Ricky-
Ricky-
MS3&MS3X v.3.0 PCB
LS3/LSA card MAF sensor
97 Mazda MX5
MS3 2002 vvt motor
.60 trim T4 Turbo at 15 PSI
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
