Source for Bosch 211 Igniter Connectors?
Postby BCM » Sun Feb 13, 2011 4:31 pm
I have an Audi version of the Bosch 211 igniter. I'm looking for matching connectors/pigtails, and I'm having a hell of a time finding a source. One is a Bosch Jetronic 4-pin, the other is a Bosch Jetronic 5-pin.
Any ideas on where I can get these? New is preferred, as I don't really have time to be cruising junkyards looking for parts.
Thanks in advance.
Brendan
Brendan
My 1990 BMW E30 M3: viewtopic.php?f=104&t=40404
NA 2.3L 4-Cyl S14, MS3/MS3X, COP, Sequential
BCM
Re: Source for Bosch 211 Igniter Connectors?
Postby 24c » Sun Feb 13, 2011 11:40 pm
AFAIK, they are called "Junior Timer" connectors, and they are characterised by their pin numbers... UK link here for picture reference
Yamaha YZF1000 MSExtra 3.1
24c
Postby BCM » Tue Feb 15, 2011 6:49 am
Thank you for that. I'd found the Tyco part numbers (I think anyways) but hadn't found anyone who would sell single connectors. And, having an extra 999 of each of these on hand wouldn't do me any good :lol:
Brendan
Brendan
BCM
Postby elaw » Tue Feb 15, 2011 12:20 pm
Brendan,
Here are a few sources a little closer to where you are:
http://www.eagleday.com/ampconnectors.html
http://www.classicricambi.com/index.php?main_page=index&cPath=143_135
http://www.mouser.com/ has a lot of stuff, search on "junior timer"
If you know the Amp/Tyco partnumber, http://www.onlinecomponents.com/ has a lot of stuff at good prices
If you need a crimp tool, this one: http://www.delcity.net/store/OEM-Ratchet-Crimping-Tool/p_714008.h_715344.a_1.t_1 is only $28, I have one and it's been pretty good.
A couple of links for general info:
http://www.vems.hu/wiki/index.php?page=ConnectorSelection
http://forums.vwvortex.com/showthread.php?4320611
One trick I found is to use connector housings (which can be expensive and hard to find) from the junkyard, with new boots (if necessary) and new terminals.
Can ya tell I've done this before? :lol:
Eric Law
elaw
Postby prof315 » Wed Feb 16, 2011 4:57 am
elaw wrote:Brendan,
I collect engine wiring harnesses for their connectors all the time. It really makes life easy but does require a handfull of depinning tools as well new pins and a good crimper.
Linfert Performance: Come run up front
92 Corrado 1.8T/ Ecotec K04 on MS3/3X
94 Ranger 2.3 Twin Plug on MS2
Support the developers!
We repair broken MS ECUs
prof315
Postby olie05 » Mon Apr 16, 2012 2:32 pm
I just ordered the connectors for my 211 igniter from the following website: onlinecomponents.com
Here are the links to the product pages:
bosch/amp 5 pin female housing p/n 282193-1
http://www.onlinecomponents.com/te-conn ... p=10325334
bosch/amp 4 pin female housing p/n 282192-1
http://www.onlinecomponents.com/te-conn ... p=10325331
bosch/amp wire seal p/n 828904-1
http://www.onlinecomponents.com/te-conn ... p=10511971
bosch/amp contact for 20-17awg wire p/n 929940-1
http://www.onlinecomponents.com/te-conn ... p=10530786
bosch/amp contact for 15.5-13.5 awg wire p/n 929937-1
http://www.onlinecomponents.com/te-conn ... p=10530776
I really hope this helps someone in their search for the connector, I was about to spend $25 per connector but then found this site and spent about $8 per connector.
olie05
Postby eMTea » Mon Dec 17, 2012 10:27 am
I want to wire the quadspark module instead of the Bosch 211, does anyone know where to find MALE connectors, so I don't need to cut in the OEM harness?
-MS3X, (V3 PCB) 1.2 RC 1 firmware. Controlling a light modified Audi 1.8TQ AEB 20v engine with Holset HE221W turbo, 299.4 HP and 400Nm at the hubs in Dynapack.
eMTea
Postby PSIG » Wed Jan 09, 2013 3:18 pm
Perhaps a bit late for you, but standard .110" male spade terminals will fit the Bosch female terminals. For reference, the female spade connectors do not fit Bosch Junior Timer connectors without re-forming, which is not recommended. You can bridge the males together with silicone RTV and use a zip-tie to retain for a more secure 'connector'. Not pretty, but it got me through a pinch with some reliability. Otherwise you can zip-bundle the male wires very close, and run a zip-tie around the connector to retain temporarily. I would squeeze a good amount of silicone dielectric grease in the females for terminal weather protection even if temporary.
David
-=≡ If it was easy, everyone would do it. ≡=-
PSIG
Postby wmax351 » Wed Feb 19, 2014 6:25 pm
4 Pin
Mouser #: 571-2821921
Mfr. #: 282192-1
Manufacturer: TE Connectivity
Desc.: Heavy Duty Power Connectors SP CONN W.S.L.
RoHS: RoHS Compliant
5 Pin:
Mouser #: 571-282766-1
Mfr. #: 282766-1
Desc.: Automotive Connectors JPT SPLASH-PROOF FEM.CONN5 POS
The terminals are standard JPT (Junior Power Timer) ones, take your pick on mouser.
wmax351
Return to OEM EFI Hardware
