here is my shematic for microsquirt V3 will post the msq later on to get it running
the oem uses a 4 wire stepper idle, that is disabled i did route +12v and fidle to it´s pins 1-2
in the cars multirelay there is 1 wire you needs to be cut and joinet to a nother ( pin 2 to pin 14 on multirelay)
there is no direct +12v line from the ignition key to ecu on marelli systems.
this ecu is used also on 106 peugeot rallye (1.6)
testing the ecu on citroen xantia 2.0 8v, 390 ohm resistor in paralel with the vr sensor.
citroen/peugeot marelli P8 replacement
Re: citroen/peugeot marelli P8 replacement
I am sure it is also possible to leave the connections on the multirelay as they are if one connection is grounded inside the ECU. I need to look in the schematics but it worked on two cars with MM-ECU so far. (1.1 litre G6.11, 1.6 litre 1AP.41)
Best Regards, Mario
Best Regards, Mario
Peugeot 106 Sergio_Tacchini, 1124cm³, MS2/Extra pre3.3alpah15, E85
Citroen AX, 954cm³, MS2/Extra pre3.3alpha15, E85
Peugeot 106 Rallye, 1298cm³ ... waiting for ITBs and full sequential injection
with the 8P ecu wireing the output´s are inverted on the multi relay
the 8p uses the multirelay pins 8*15 and 13*5*6*4 to feed the pover to injectors, coil etc.. no direct output for the ecu.
the ecu pover is fed trough 11 and 1*9 and the relay coil is fed direct from the batery.
the bosch wireing diagram that has the inverted multirelay output motronic 3.2 for example can be wired without the mod same as 1Ap
simply it can´t be done witout the mod or you would have to leve one relay constantly on that would drain the batery
Ok - i see my car is already wired this way from the factory. I will never understand why the guys at PSA use to solve the same problem in different ways on similar cars...
Mario
Mario
hello, does anyone here have this images? the pictures didnt appear
Dear turtana,
is there a chance you still have the photos of the modified multi-relay and VR sensor? They are not showing at all...
If you have more photos would be really helpful for us trying to replace the Marelli 8p...
Thanks in advance!!
Thanks in advance!!
