Hi to all.
I have a fuel component that has a strange (to me , at least) thread .
I need to find a banjo screw and banjo coupling that has the screw with a 7/16"-24 tpi thread.
Normal UNF is 7/16".20 tpi, and the rare UNEF is 7/16"-28 tpi.
The part I have is right in the middle, ie 7/16"-24 tpi. Can anybody help, please.
W113
7/16-24 TPI Banjo bolts
If not understood , it will not work
Re: 7/16-24 TPI Banjo bolts
could it possibly be metric, 11mmx1.0 or .08 thread?
Is it by any chance a UK part?
Rover SD1 3.5 EFI
MS2 V3
Tech Edge O2
London UK.
MS2 V3
Tech Edge O2
London UK.
Hi guys.
It is not a metric part, but if a sufficiently close banjo bolt is available I would go for that. But a 11 mm with a pitch of 1,05 seems like not realistic. 11mm with a pitch of 1,0 would be half a thread off in 10 turns, so that part would seize/break.
The part sits in a Pantera imported to Sweden from the US. It is probably a US installed part.
And I have found some 7/16" x 24 tpi thread tools for sale on US sites, so it is not totally unknown.
I may have to end up making the banjo bolt and then use a standard 7/16" banjo, but only as a last resort.
So, anybody with a good source of strange banjo bolts, please let me know.
Thanks a bundle.
Ola
Thanks a bundle.
Ola
I googled it, bunch of sites popped up, but looks like you can find it on eBay.http://www.ebay.com/itm/like/261302698148?lpid=82
Easy google search: http://www.jegs.com/i/JEGS-Performance- ... ProductId=
1984 Mazda RX-7 GTM Class (BP Engine + BW-EFR 8374 Turbo Full COP/Sequential on MS3+MS3x)
1986 Toyota 4Runner (22RE running on MS2-Extra 3.2.1)
Thanks a LOT, guys.
You have solved my problem! Great.
Best regards,
W113
Best regards,
W113
