I'm installing MS2 Extra to an 1992 Audi V6 and despite it not being 'the prefered method' I want to retain the factory fitted Bosch ignition module (I intend this to be a plug and play installation that will allow me to switch back to the factory ECU)
How can I tell if this unit is smart or dumb?
How to tell if a Bosch ignition unit does dwell?
'82 Golf GTI ABF 16v MS2 Extra sequential COP
'77 Scirocco G60 MS2 Extra sequential
Re: How to tell if a Bosch ignition unit does dwell?
As far as I'm away the built-in dwell modules were only used standalone directly connected to a dizzy. Any module that was controlled by an ECU I would expect to require dwell control in Megasquirt.
Nothing wrong with keeping that module either - it should be perfectly matched to the coil.
Thanks for the quick response James.
