Hi
Unrelated to MS, I have an AEB 1.8T and the fuel pressure reg sits too high and fowls the bonnet (hood) in a custom install. Is there a lower profile fuel rail on another 1.8T that might fit?
I can simply modify the fuel rail, but this might be easier.
Patrick
vag 1.8T gurus?
vag 1.8T gurus?
Currently Lotus 23C replica Audi 1.8T MS 2 v3 Sequential COP and ignition.
Lotus 7 replica 4age 20V blacktop MS2 v3
Re: vag 1.8T gurus?
THere are 2 types of OEM fuel rails. One that sits lower, and one higher, but this will be a match to the intake manifold.This will also change the kind of injectors you can run. Tall vs short.
So, maybe the change of the fuel rail might be easier for you, and add an external fuel pressure regulator?
