Hemi fuel injector?
Hemi fuel injector?
I got a set of 4591851AB mopar injectors from a 2006 300c with a 5.7L Hemi. I was wondering if some of you Dodge gurus had an idea how much this injector flows.
Ricky-
MS3&MS3X v.3.0 PCB
LS3/LSA card MAF sensor
97 Mazda MX5
MS3 2002 vvt motor
.60 trim T4 Turbo at 15 PSI
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
Re: Hemi fuel injector?
Pretty sure they're 30lbs at 59psi. All LX (300, Magnum, Charger) LC (Challenger), platforms run 59psi fuel pressure both RT and SRT8. SRT8's have 34lb inj.
Sometimes there's only one way to find out! Just do it!!!
well I tried 2 differant pressure gauges during the test. This particlular injector which is from a 2006 300c flows 310ccs in 60 seconds .at 12 volts.
Ricky-
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
