effects of shorting a hall sensor
What would happen if I connected the signal wire from a hall sensor (camshaft position sensor) to 5v? Would this kill the sensor?
What are the symptoms of a dead sensor?
'82 Golf GTI ABF 16v MS2 Extra sequential COP
'77 Scirocco G60 MS2 Extra sequential
Re: effects of shorting a hall sensor
Is this a sensor that uses a pull-up resistor, as opposed to a pull-down? If so, yes, there is a good chance it has been damaged. You can bench-test it to prove if it is definitely bad, but not that it is good for sure. The damage done may be subtle and not pop-up except under certain operating conditions of temperature, vibration, humidity, frequency, etc. I would test it by simply trying it with the engine, if it works OK then use it. However, if there is ever any sync-loss issues, toss that sensor as the first step in trouble-shooting.
Thanks Bill.
I'm using a JB Perf divider board and theres a pair of jumpers to select between normal and inverted for the opto sensor, I'd made the jumpers as short loops as I knew I wanted to attach scope probes, unfortuantly it appears they have been knocked so they touch which means the 5v supply is connected to both the + and the signal line on the hall sensor. Same thing for the opto, hopefully that can cope..
Did you have both an opto and Hall sensor connected (at different times) with the mis-connection? Maybe I'm getting confused... are you concerned about damage to a sensor, or to the MS tach input?
Hi Bill,billr wrote:Did you have both an opto and Hall sensor connected (at different times) with the mis-connection? Maybe I'm getting confused... are you concerned about damage to a sensor, or to the MS tach input?
The JB Perf board has a pair of jumpers that allow you to invert the signal between the hall sensor and the opto isolator.. fit them one way and the opto will produce a signal when the hall goes low, fit them the other way and the opto will produce a signal when the hall goes high.
By shorting the jumpers I applied 5v to both wires from the hall and both 'wires' to the opto isolator..
Okay, I get it now. The "opto" is an opto-isolated output from the circuit, not an opto sensor. Since this was on a JB board, maybe JB will chime in on what the chances are that the board could get damaged. I have never even seen one.
This is for Jean..
I now have a working Hall Sensor.
However, the JB Perf divider board is not giving the output I expect.
135 teeth on flywheel
1 TDC notch in crank
JB Perf jumper set to divide by 3. I expected 135/3 =45. So set Tuner Studio to 'toothed wheel', 45 teeth, 1 missing tooth.
I appear to be getting 20-1 or 21-1
I've attached my MSQ and the tooth logger file..
Martin
Martin
Please post a composite log. It is much easier to analyze than the tooth logger.
OK, a composite log will take time as I'm now feeding my daughter
What else does it give you? I have no other ignition capture signals other than the JB Perf board output to tsel
Hello Jean,
I did say a composite log would take a while....
That confirms what was in the tooth log (but is easier for me to assess in the composite logger). Your setup is missing a lot of teeth as you can see in the composite log as the very long gaps. So there is either a problem with the VR sensor, the VR conditioner circuit, the CPU on the divider board or the connection to the MS.
The only way I can see is to use an oscilloscope and follow the signal through the whole chain.
