Simple question,
On an basic ignition system, like the Bosch system fitted to VW's in the 80's, with a hall sensor and 4 window wheel in the dizzy, what controls the dwell?
Is it simply the width of the window?
Dwell on TCi ignition
'82 Golf GTI ABF 16v MS2 Extra sequential COP
'77 Scirocco G60 MS2 Extra sequential
Re: Dwell on TCi ignition
No in a smart dwell module it is the values of certain internal electronic components that determines the dwell, not the window length. If it were based on window length you would somehow need a window that was about 4 degrees wide at idle and about 13 degrees at 6Krpm.
Cheers Luke
Cheers Luke
That's what I thought, but I was told by someone who appeared knowledgeable that non of the Bosch tci units were smart
The Bosch 0 227 100 137 / 0 227 100 139 are well known smart dwell hall effect modules.
These have also been listed as smart dwell before.
0 227 100 100,
0 227 100 101,
0 227 100 103,
0 227 100 104,
0 227 100 113,
0 227 100 116,
0 227 100 118,
0 227 100 137,
0 227 100 138,
0 227 100 139,
1 227 010 001,
1 227 010 004,
1 227 022 008,
211 905 351,
211 905 351 A,
211 905 351 B,
211 905 351 D,
211 905 351 E
0 227 100 100,
0 227 100 101,
0 227 100 103,
0 227 100 104,
0 227 100 113,
0 227 100 116,
0 227 100 118,
0 227 100 137,
0 227 100 138,
0 227 100 139,
1 227 010 001,
1 227 010 004,
1 227 022 008,
211 905 351,
211 905 351 A,
211 905 351 B,
211 905 351 D,
211 905 351 E
Cheers Luke
Cheers Luke
