should I change my plug gap now wih EDIS?
I've changed out my TR6 from point to Ford EDIS. Should I increase the spark gap? Anything else I should think about?
1972 Triumph TR6
Dual Extrudabody ITBs
Megasquirt 2 extra/V3
Re: should I change my plug gap now wih EDIS?
What is your current gap?
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
Have you changed the plugs to a resistor type? EDIS seems to need these. Try 35 thou. as a gap.skikir wrote:I've changed out my TR6 from point to Ford EDIS. Should I increase the spark gap? Anything else I should think about?
