VAG 1.8T Audi VW
lotus23C
VAG 1.8T Audi VW
Post by lotus23C »
Hi
Can anyone tell me if the single timing mark on the pulley is TDC or 10 deg BTDC?
Thanks in advance
Patrick
24c
Re: VAG 1.8T Audi VW
Post by 24c »
Hi lotus23C
Somewhere deep in the grey stuff, I remember doing a timing belt, so when the notch in the crankshaft pulley is aligned with the dimple in the cover above the pulley, the engine is at TDC, but why not take a plug out & look in the hole with a torch or use a "stick", and turn the engine with a spanner and check for TDC pulley alignment that way. :?
Mike
Yamaha YZF1000 MSExtra 3.1
prof315
Post by prof315 »
I'm pretty sure it's TDC
Support the developers!
