Can someone please help with wiring pinouts on a denso MRE (magneto resistive element) crank sensor (found on Toyota Tundra, Sequoia and Landcruiser) P/No. 90919-05071
After battling with stock 1UZFE VR sensors, I'm giving one of these a go. I've already machined up an adapter and purchased a short pigtail with OEM plug to suit.
They're a 3 pin plug on the sensor being 5 volt, signal and ground, but I don't know which is allocated to which pin.
Also, should I need a pullup resistor between the 5 volt and the signal pins?
Any assistance would be greatly appreciated.
Denso MRE crank sensor
Re: Denso MRE crank sensor
whats your problem with the stock sensor...
i am already tune and build many of this v8 non vvti and also vvti edition for race purposes and street....
i am using all of them in stock sensor and already tune the vvti also
what type of ms u using
