This whole "throttle blipping" for overdrive engagement has led me down yet another research rat hole - electronic throttles.
Delco seems to make quite a few that are very compact. They have a six pin connector, with two pins to the motor, and the rest to two out of phase TPS, for redundancy, I suppose. What kind of motor is it, if it has just two leads? A spring-loaded (throttle shut) motor that is PWM'd to an open position?
I wonder if they dispense with an idle control motor by simply actuating the throttle.
Thanks.
Delco Electronic Throttles - what makes them tick?
Re: Delco Electronic Throttles - what makes them tick?
It is a servo motor and you need a servo controller (with safety critical design) to operate it.
As James notes, it's a dumb 2-wire DC motor. Apply +/- voltage, it turns one way, apply -/+ it turns the other. The 2 TPS are for error trapping and are part of the safety system.
I have a small card that turns a PWM signal into something that will drive a 5-wire servo (2 motor wires + 3 for the SPS) for something like a Yamaha EXUP valve. I wouldn't even consider using it on a throttle - something goes wrong, and that throttle suddenly pins WFO as you're approaching a cross-walk full of nuns and orphans ...
Electronic throttle control is for those with deep pockets, both for safety design and testing, and for liability lawsuits.
Thanks to you both.
It's an interesting area and there are Safety Critical H-bridges just for this that are pretty sophisticated, with SPI interfaces for diagnostics and dual uC's. Not that I'm going to implement DBW but it's a good mental exercise. Bosch even gives you 3D models of their universal DBW throttles, to encourage you to tempt fate.
Nuns and orphans; funny!
