I am using the LS D585 coils and have them directly on the plug in a non-LS application
I would like to move them off the coil so i need to figure out spark plug wires. Long story short is that i have the spark plug side worked out (custom weird application) but do not have the hardware (boots/clips) for the coil side. I have been looking around and seems like there are millions of options for a standard application (short wires complete) but I have not been able to find anything that just has the hardware for the coil side (or just a DIY build your own wire kit)
Maybe i am looking in all the wrong places- I am sure somebody has done this with how many use the D585- any tips appreciated
LS coil spark plug wires-Custom application
Re: LS coil spark plug wires-Custom application
I've bought some coil ends from msd, they come in a 2 pack with 2 boots and metal clips. Draw back is the coil boot is the standard 30* LS angle or so and for a 7mm wire
Thanks for the tip i will look closer at msd... but i know what you mean. i was wanting a straight one on the coil side, seems like they all have an anglenathaninwa wrote:I've bought some coil ends from msd, they come in a 2 pack with 2 boots and metal clips. Draw back is the coil boot is the standard 30* LS angle or so and for a 7mm wire
I second MSD but yes, there's that funny angle on the coil side.JAM wrote:Thanks for the tip i will look closer at msd... but i know what you mean. i was wanting a straight one on the coil side, seems like they all have an anglenathaninwa wrote:I've bought some coil ends from msd, they come in a 2 pack with 2 boots and metal clips. Draw back is the coil boot is the standard 30* LS angle or so and for a 7mm wire
A suggestion - the RX-8 crowd uses the D585 as an upgrade to the problematic OEM coils. There are vendors offering kits that include a mounting bracket and wire set. It may be worth seeing if they have a straight lead DIY end.
thanks for the info and help, i was unable to locate any straight boots but i did find the msd units and ordered them
for any future reference the PN is MSD Ignition 3304
I found an E-bay vendor, who offered custom length plug wires.
Try Accel 170180-8
