Well I finally got around to mounting my coil and making the spark plug leads connect to the coil towers using the LS connectors.
Have a look at my blog if your'e interested. Thanks to everyone for your help, and a big thanks to Prof315 for the info on the LS connectors.
Jim
VW Coilpack connectors wanted
Re: VW Coilpack connectors wanted (SOLVED)
1968 Australian Morris Mini fitted with a 1310cc A+ engine
14point7 WB, TunerStudio MS Ultra & MegaLogViewer HD
My Blog: http://www.jims-blog.com
I shop a lot at Rock Auto. I think they ship internationally. When I find a coil that looks like it might work, I order a set of plug wires from the matching vehicle. They usually have pictures of what they sell. Since I'm building a motorcycle project, I need to use plug caps, so any 7mm or so wire will work. I just cut the wires to length and thread on the plug caps.
1981 Suzuki GS1000G & 1992 GSX1100G Microsquirt Projects
Adapting fuel injection mostly from a 2003 GSXR600
Hearing "It can't be done" is SOP around here.
Thanks for that. I finally fitted LS1 connectors that are 'close' to the Volkswagen Audi connectors. See my blog for the results.
I saw that & am glad you found a solution. I like to post information/alternatives for those that may find this thread in the future, as I did.
