Bosch MAF sensor voltage curves
Here is a datasheet with some of the curves for Bosch sensors:
0 280 217 123
0 280 218 019
0 280 217 531
0 280 218 008
0 280 002 421
0 280 212 016
The .inc files are located here:
http://home.online.no/~krbjhvee/MAF/
Feel free to add more data if anyone have the voltage curves for more sensors.
Source:
http://modshack.info/images/sensors_airmass.pdf
0 280 217 123
0 280 218 019
0 280 217 531
0 280 218 008
0 280 002 421
0 280 212 016
Source:
Last edited by 357supermagnum on Sat Apr 25, 2015 7:10 pm, edited 6 times in total.
Re: Bosch MAF sensor voltage curves
These curves should apply to all other HFM5 part number as well, AFAIK they all use the same sensor but have different connectors. Just apply the curve for the MAF with the same inner diameter housing.
MAF curve will probably have to be tuned a slight bit afterwards due to upstream flow disturbances, but shoould be close.
Joachim
1974 Jensen-Healey
2014 Ford Fiesta EcoBoost
1974 Jensen-Healey
Original post updated with the data for:
0 280 212 016
0 280 212 016
Hi there, i'm trying to find the curves for a HLM 2-10 MAF sensor, Bosch 0280 213 006 (Volvo B280 V6) , anyone have a tip ?
Thank you .
Thank you .
Challenge everything
Install the MAF, tweak till it starts, then adjust the curve as described elsewhere here on the forums. Two drives of 20 minutes each should get you well inside the ballpark.
Joachim
1974 Jensen-Healey
1974 Jensen-Healey
My problem is i don't know the values for max Flow to set the table right ( i put 650 g/s sensor range, but don't know ? )
Multiply g/s by 1.25 for an estimate of max supported horsepower. You will not need the other scaling options.
Joachim
1974 Jensen-Healey
1974 Jensen-Healey
Hello,
Links are dead. Can someone repost the curves please ?
Regards,
Manu
Regards,
Manu
Old broken links! Wayback Machine is your friend here.
Try this: https://web.archive.org/web/20151031131 ... jhvee/MAF/
Also found this from Bosch: http://rb-aa.bosch.com/boaasocs/index.j ... ccat_id=72
BR,
Matthias
BR,
Matthias
BR
Matthias Frithioff (Mafritech)
R&D Engineer
Car Mech. & B.Sc. ME
R&D Engineer
