Any recommended Throttlebody 3"+ with built in ICV
eMTea
Post by eMTea »
As topic says.
I need a Throttlebody for my future 24v VR6 project, and I want one with built in ICV that MS3X can control.
-MS3X, (V3 PCB) 1.2 RC 1 firmware. Controlling a light modified Audi 1.8TQ AEB 20v engine with Holset HE221W turbo, 299.4 HP and 400Nm at the hubs in Dynapack.
nathaninwa
Re: Any recommended Throttlebody 3
Post by nathaninwa »
I like to tune using pwm style idle motors. First thing that comes to mind is any 5.0 mustang will have it built in and plenty of sizes and brands avaialable for that motor
One thing to look out for it throttle pull direction
subwoofer
Re: Any recommended Throttlebody 3"+ with built in ICV
Post by subwoofer »
Not many Mustangs this side of the pond...
Joachim
1974 Jensen-Healey
2014 Ford Fiesta EcoBoost
Laminar
Post by Laminar »
Can you order from Summit?
http://www.summitracing.com/oh/parts/su ... /overview/
75mm (2.95"), built in prep for IAC valve and TPS (neither are included), both of which are directly compatible with MS.
eMTea
Post by eMTea »
Seems like a good alternative!
I'll just check out ebay for a complete one.
eMTea
Post by eMTea »
Do you think this one will fit for a mustang? I'd like to stick with Bosch Style connectors as long as possible.
http://www.ebay.com/itm/1x-LEERLAUFREGE ... c4&vxp=mtr
nathaninwa
I have found so far that any ford iac swaps over, there is just differences in motor style and connector location. Look for something bbk if you can, all of there throttle body's come stock with oring shafts. A buddy had that summit one and it whistled pretty bad through the throttle shaft till we oringed it
eMTea
Post by eMTea »
BBK?
nathaninwa
BBK is a brand name
eMTea
Post by eMTea »
OK, sorry, not familiar with US cars really :p
eMTea
Post by eMTea »
This one maybe? http://www.ebay.com/itm/BBK-1514-Thrott ... 65&vxp=mtr
Will 80mm suffer from low rpm drivability?
nathaninwa
It's no problem, sometimes I forget this is a worldwide board, which I think is great as diverse information gets about
What size is the engine? You can mask the to large or throttle body syndrome with a progressive type spool. When I have to modify a spool, I work it out where 1/2 pedal throttle is 1/4 throttle body movement, then it Gos wot after that
eMTea
Post by eMTea »
It's a 2.8 24v VR6, originally from Seat Leon Cupra R. 204hp. Will be boosted to about 700hp.
I see, I was first thinking of trying to adopt my oem throttle cable connection, but an offset wheel would probably solve the drivability issue, if there is any.
Laminar
Post by Laminar »
nathaninwa wrote:A buddy had that summit one and it whistled pretty bad through the throttle shaft till we oringed it
Mine whistles like crazy...I'll check the throttle shaft!
nathaninwa
What caught our attention first was during a boost leak test, the tps was bubbling!
That 80mm might be a big large. I'm running 3 inch piping all the way with a 70mm throttle body. It has a 3 inch coupling diameter so it flows to the eye, and internally I put it on the lathe and tapered the entry for better flow. I had to reduce the throttle change off idle with the spool to stop the motor from flaring up while taking off from a stop. Mines a 3.0L and makes over 800whp with the choke point being the turbine housing and back pressure sky rocketing
On a side note, a buddy with form of gt35 made almost 830whp in an Evo with 2.5 inch piping and stock 65mm throttle body. When he went to 3 inch and a 75mm throttle power went to 880 iirc, so it's not that much of a restriction
eMTea
Post by eMTea »
Ok, I think I'll go for the 70mm instead then, then all the piping and hoses can be done with 3" OD/ID. Seems plenty enough for me. Thanks for the advice!
nathanhardy
Post by nathanhardy »
I run 75mm Wilson manifold ford mustangs throttle body on my vr6 12v with a short runner intake and it idles fine
98 VW golf gti vr6 turbo 8:5:1 cr ported and polished full ferrea race valves train 276 cams custom short runner intake Borge 366 sx-e turbo forge wossner pistons, balanced rotating mass, limited slip 6 speed deka 750Lbs injectors on ms3pro completed AWD swap
