Can anyone help me out with voltage vs. pressure on this map sensor?
It was located inside the ECU box soldered directly to the board.
Bosch on-board MAP sensor (1267632015) voltage vs. pressure?
Re: Bosch on-board MAP sensor (1267632015) voltage vs. press
maybe this (200kPa) one:
http://www.farnell.com/datasheets/49036.pdf
Not sure, I found that pdf the other day too, but part numbers are at not matching, so not sure.
Most Bosch partnr's start with a 0.
The number youre revering to could be the part number from a car manufacturer.
Live would be much easier and cheaper if they all used the same number for identical parts
Ok. The other file linked to was for 250 and 300kPa sensors.
I found this today (http://datasheet.seekic.com/datasheet/0273003204.html#), which have the curves for 105kPa and 200kPa sensors.
Just for reference.
What I found in the end is the following:
Trykksensor 105 kPa
273003203
Spenning Trykk
[V] [kPa]
0 12.45
0.4 20.00
4.9 105.00
5 106.89
Trykksensor 200 kPa
273003204
Spenning Trykk
[V] [kPa]
0 10.13
0.25 20.02
4.8 200.02
5 207.93
Trykksensor 250 kPa
273003210
Spenning Trykk
[V] [kPa]
0 10.00
0.2 20.00
4.8 250.00
5 260.00
Trykksensor 300 kPa
273003211
Spenning Trykk
[V] [kPa]
0 -6.36
0.4 20.00
4.65 300.00
5 323.05
Just for reference.
Trykksensor 105 kPa
273003203
Spenning Trykk
[V] [kPa]
0 12.45
0.4 20.00
4.9 105.00
5 106.89
Trykksensor 200 kPa
273003204
Spenning Trykk
[V] [kPa]
0 10.13
0.25 20.02
4.8 200.02
5 207.93
Trykksensor 250 kPa
273003210
Spenning Trykk
[V] [kPa]
0 10.00
0.2 20.00
4.8 250.00
5 260.00
Trykksensor 300 kPa
273003211
Spenning Trykk
[V] [kPa]
0 -6.36
0.4 20.00
4.65 300.00
5 323.05
