Honda Keihin TPS Connector
oscarmax
Post by oscarmax »
I am struggling to find a new Honda CBR600RR 2011 Keihin TPS connector, I have tried a Mikuni connector, bit it is slight to large.
dontz125
Re: Honda Keihin TPS Connector
Post by dontz125 »
CBR F4, F4i TPS 99-06' (harness side)
(A less blurry photo is always helpful ...) :D
oscarmax
Post by oscarmax »
I must admit it is bad, unfortunately I was trying to take a photographs whole balancing on my crutches. Anyway I shall order one.
oscarmax
Post by oscarmax »
dontz125 wrote:CBR F4, F4i TPS 99-06' (harness side)
I am still after a Keihin TPS connector for Keihin TPS JT7H 90726, I purchased one from the above, but is does not fit.
dontz125
Post by dontz125 »
Send a *good* pic to Alex at Corsa Technic, see what he suggests.
prof315
Post by prof315 »
Its very likely this http://www.bmotorsports.com/shop/produc ... ts_id/2189 I know it fits Keihin Honda/Acura automotive throttle body TPS
Support the developers!
1vayl0Pavl0v
Post by 1vayl0Pavl0v »
Civic VII Type S use the same clock side TPS JT7H as most of the CBRs.Prelude 2.4 have the same TPS but with 90 degree rotated,so both have the same conector.
