Honda Keihin TPS Connector
I am struggling to find a new Honda CBR600RR 2011 Keihin TPS connector, I have tried a Mikuni connector, bit it is slight to large.
Re: Honda Keihin TPS Connector
I must admit it is bad, unfortunately I was trying to take a photographs whole balancing on my crutches. Anyway I shall order one.
I am still after a Keihin TPS connector for Keihin TPS JT7H 90726, I purchased one from the above, but is does not fit.
Send a *good* pic to Alex at Corsa Technic, see what he suggests.
Its very likely this http://www.bmotorsports.com/shop/produc ... ts_id/2189 I know it fits Keihin Honda/Acura automotive throttle body TPS
Support the developers!
Civic VII Type S use the same clock side TPS JT7H as most of the CBRs.Prelude 2.4 have the same TPS but with 90 degree rotated,so both have the same conector.
