Honda CBR600 RR Throttle Bodies Air Valve
I would like to run my Honda CBR600RR 2012 4 pin air valve, unfortunately my Microsquirt does not have that capabilities, I know what the alternatives are, but ideally like to use this set up.
Re: Honda CBR600 RR Throttle Bodies Air Valve
if it has 4 pins its more than likely a stepper motor, i believe there is an add-on you can get to allow you to run one on a microsquirt at the expense of losing some of the other outputs.
