http://www.efi-parts.co.uk/products_pic ... nt-npt.jpg
Does anyone know which terminal is +ve and ground it is a NTC
FAE Water Temp Sensor
Re: FAE Water Temp Sensor
if its ntc its basically a variable resistor so either way will work.
Thank you for your help.
Melvin
Melvin
