microsquirt and chargecooler pump
oscarmax
Post by oscarmax »
Can my Microsquirt V3 run my chargecooler pump
grom_e30
Re: microsquirt and chargecooler pump
Post by grom_e30 »
if you have a spare out put, fidle, aled or wled, they you could use that to drive a relay to turn on under certain conditions (programmable out ports) like if map is higher than x kpa turn relay on, you can also set a second condition as well so if kpa > 150 & mat > 35 it will only turn on when the kpa is higher and if the manifold temp is above 35
oscarmax
Post by oscarmax »
grom_e30 wrote:if you have a spare out put, fidle, aled or wled, they you could use that to drive a relay to turn on under certain conditions (programmable out ports) like if map is higher than x kpa turn relay on, you can also set a second condition as well so if kpa > 150 & mat > 35 it will only turn on when the kpa is higher and if the manifold temp is above 35
I have used the Fidle to run a relay to my chargecooler pump, what data settings do I need to put into my Microsquirt V3, also can I use the same relay to controller my water injection ?
grom_e30
Post by grom_e30 »
I would run the charge cooler pump off the ignition or fuel pump relay possibly, that way its always running when the engine is, as to water injection i would guess that would only be needed under boost so would be better to let the ecu control that.
oscarmax
Post by oscarmax »
grom_e30 wrote:I would run the charge cooler pump off the ignition or fuel pump relay possibly, that way its always running when the engine is, as to water injection i would guess that would only be needed under boost so would be better to let the ecu control that.
Hi I have ditched the water injection idea, due to cost, thank for the help.
