Microsquirt and Wiring Ford 20uF Noise Capacitor
I have managed to purchase a brand new old stock Ford Noise Suppression Capacitor 89AB12A19AA with James Murray's help. My set up is Microsquirt V3 and ford EDIS4, I realise the capacitor need to goes as close as possible to the coil pack and the feed from the module, however, I am a little confused about the final connections of the noise capacitor.
Re: Microsquirt and Wiring Ford 20uF Noise Capacitor
The factory plug has one wire that connects to 12V by the coil. The capacitor grounds through the bolt.
I'll see if I can get at my wiring later on to figure out which pin it is.
Wonder if it's a 'feed through' type? They used to be the definitive suppressors. Used on military vehicles with radio comms.
I notice you are using a Techedge o2, that is my next step in the new year 2J9DaveEFI wrote:Wonder if it's a 'feed through' type? They used to be the definitive suppressors. Used on military vehicles with radio comms.
im not sure but the 2 pins have continuity to each other, and they both measure the same capacitance reading from pin to ground.
Your description certainly sounds like a feed thru to me.........grom_e30 wrote:im not sure but the 2 pins have continuity to each other, and they both measure the same capacitance reading from pin to ground.
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
