I am going to connect my Microsquirt v3 to the Techedge 2J9 and just wanted to check that I am connecting the wires up right.
I am connecting the Wblin+ to the Wideband O2 input wire that goes to Pin 34 (Pink) and the Wblin- to the sensor earth points of the Ms, do I remove the link wire between the WBlin- and Ground.
I have a 5 amp fused/relay ignition supply, the o2 controller can we located closed to the power supply and Microsquirt ECU
Is this correct and do I need to connect any other wires to make it work. Looking wbo2.com and supplied instructions are a bit confusing.
Techedge Wideband o2 Controller
Re: Techedge Wideband o2 Controller
Yes you have to remove the jumper between wblin- and gnd.
All done thanks
Removing the link gives you a separate signal and power ground, so doesn't mix those together at MS as some other types do.
Rover SD1 3.5 EFI
MS2 V3
Tech Edge O2
London UK.
MS2 V3
Tech Edge O2
London UK.
