Techedge Wideband o2 Controller
oscarmax
Post by oscarmax »
I am going to connect my Microsquirt v3 to the Techedge 2J9 and just wanted to check that I am connecting the wires up right.
I am connecting the Wblin+ to the Wideband O2 input wire that goes to Pin 34 (Pink) and the Wblin- to the sensor earth points of the Ms, do I remove the link wire between the WBlin- and Ground.
I have a 5 amp fused/relay ignition supply, the o2 controller can we located closed to the power supply and Microsquirt ECU
Is this correct and do I need to connect any other wires to make it work. Looking wbo2.com and supplied instructions are a bit confusing.
Manu
Re: Techedge Wideband o2 Controller
Post by Manu »
Yes you have to remove the jumper between wblin- and gnd.
I can supply, repair or upgrade Megasquirts in FRANCE.
https://www.megasquirt.fr
oscarmax
Post by oscarmax »
All done thanks
DaveEFI
Post by DaveEFI »
Removing the link gives you a separate signal and power ground, so doesn't mix those together at MS as some other types do.
