I am after the Bosch 058905379 air intake temp sensor calibration chart due to the design I do not fancy testing in cold water.
I am after readings @ 20 degrees, 0 degrees and 100 degrees Centigrade
Bosch 058905379 Air Intake Temp Sensor Calibration Tables
Re: Bosch 058905379 Air Intake Temp Sensor Calibration Table
X
I found this link.http://rush.smolly.nl/changes/change4_2.htm
Bosch 0589055379 5v npt
Rate Resistance
R(0 degrees) = 5200 Ohms
R(22 degrees) = 2200 Ohms
R (100 degrees) = 200 Ohms.
Rate Resistance
