DENSO idle air valve
I've a DENSO idle air valve part number 22650AA181 fitted to a Subaru EJ207 engine.
simple question, is this a straight on/off valve or does it require PWM control?
Re: DENSO idle air valve
its not a simple question its got 3 dam wires
yes it require pwm control circuit to operate
m2 extra v3.57 3sgte full sequential injection V1.1A P&H Board
full sequential spark low current c.o.p.
holset turbocharger
holset turbocharger
they are information in the manual how to
holset turbocharger
holset turbocharger
yes ive found another thread on the subject
thank you tho
thank you tho
The manual says supply power and 2 pwm controls. When i look at what i think is the correct wiring diagram for the engine bay it is identified as a 'idle air control solenoid valve', it has 3 connections power gnd and signal.
any thoughts on this?
There is a Bosch three wire unit that you apply power to one, ground another through a resistor (to pull it closed), and use pwm to open it on the third.
Which MS hardware are you using? Actually I'm going to assume ms3x since I just looked at which forum this is under. Either way if you follow the manual/diagram there is an output for it. I'm using the same hardware but on EZ30.
