DENSO idle air valve
emlclcy
Post by emlclcy »
I've a DENSO idle air valve part number 22650AA181 fitted to a Subaru EJ207 engine.
simple question, is this a straight on/off valve or does it require PWM control?
emlclcy
Re: DENSO idle air valve
Post by emlclcy »
its not a simple question its got 3 dam wires
davcol
Post by davcol »
yes it require pwm control circuit to operate
m2 extra v3.57 3sgte full sequential injection V1.1A P&H Board
full sequential spark low current c.o.p.
holset turbocharger
davcol
Post by davcol »
they are information in the manual how to :RTFM:
holset turbocharger
emlclcy
Post by emlclcy »
yes ive found another thread on the subject
thank you tho
emlclcy
Post by emlclcy »
The manual says supply power and 2 pwm controls. When i look at what i think is the correct wiring diagram for the engine bay it is identified as a 'idle air control solenoid valve', it has 3 connections power gnd and signal.
any thoughts on this?
rickb794
Post by rickb794 »
There is a Bosch three wire unit that you apply power to one, ground another through a resistor (to pull it closed), and use pwm to open it on the third.
gearhead
Post by gearhead »
Which MS hardware are you using? Actually I'm going to assume ms3x since I just looked at which forum this is under. Either way if you follow the manual/diagram there is an output for it. I'm using the same hardware but on EZ30.
