I am putting a 2008 l15a into a small jet boat. I want to use as much oem hardware as possible.
I'm trying to figure out the ignition but can't find much info about Honda and none about this motor. I am not sure how to test the cop's to see how they should be wired.
Also, how do I test the crank position sensor to see what type it is and how to connect it?
Since the engine is a vtec I am leaving the cam advancement system disconnected and plan on figuring it out later.
Thanks, Matt
Honda l15a (2008 fit/jazz) cop
Re: Honda l15a (2008 fit/jazz) cop
Are these Nippon denso cops like the stream k20 k24 ones?
If so then they are just like the Toyota 4 wire 1nz cops. Logic level easy. 12v, ground, logic, feedback (unused)
Details in ms3 manual think.
