Decapping injectors
ol boy
Decapping injectors
Post by ol boy »
Saw a wiki on sloppy mechanic on grinding off the small orfice plate on factor GM injectors to bring the flow rate from 24lbs to 60+. I flowed a set of injectors after they were decapped.
Seems to be quite the delta from min to max. If you have several sets one could match up 8. Units are in grams/min.
Sent from my SM-G920V using Tapatalk
