EV1 - EV6 injector compatable?
lotus23C
Post by lotus23C »
Hi
I have got a bit of conflicting info on the net.
Am I correctin saying an EV6 injector is a straight swap with an EV1?
I realise some of the OEM plugs might differ and that EV12s are definitly different.
thanks
nathaninwa
Re: EV1 - EV6 injector compatable?
Post by nathaninwa »
When it come to that, style doesn't really matter. It's more to do with high and low impedance
I've swapped from ev1 to ev14 with no troubles, and on one car I run ev14 primary's and an ev1 as secondary's
All high impedance
lotus23C
Post by lotus23C »
thanks a lot
Blown88GT
Post by Blown88GT »
EV1 fuel injectors are often referred to as the “fat” style fuel injectors. The EV6 fuel injectors replaced them in the next line of fuel injector evolution. The EV6 injector is nearly identical in height but the body of the fuel injector is narrower or “skinnier” when compared against the EV1 injector. The third style is the EV14 fuel injector. The EV14 injector is shorter that the EV1 and EV6 injectors and features a slim style body.
Different Styles of Fuel Injectors:
EV1 fuel injectors
EV6 fuel injectors
EV14 fuel injectors
Different style connectors:
Jetronic/Minitimer
USCAR
