Rover 3500 Vitesse injector dead times, 0280150105
spitnl
Post by spitnl »
I have just tested these using MS2 V3.0 and the original power resistor pack.
Manufacturer: Bosch
Part Number: 0280150105
Injector Dead time @13.2V (ms): 0.537
Battery Voltage Correction (ms/V): 0.178
Flow (cc/min): 180 @ 36psi/2.5bar
I've not checked this, but according to another website they were fitted to:
INJECTOR BOSCH 0280150105 ERC3620 RANGE ROVER CLASSIC 3.5 LAND ROVER DISCOVERY 3.5 MGB V8 PORSCHE 916 RENAULT 1981 Triumph TR8 3.5L VIN 5 # 0280150105 Fuel Injector ALFA ROMEO 1981 GTV-6 2.5L 6 Cyl. Fuel Injector MM 0280150105 ALFA ROMEO 1982 GTV-6 2.5 2.5L 6 Cyl. Fuel Injector MM 0280150105 ALFA ROMEO 1983 GTV-6 2.5 2.5L 6 Cyl. Fuel Injector MM 0280150105 ALFA ROMEO 1984 GTV-6 2.5 2.5L 6 Cyl. Fuel Injector MM 0280150105 ALFA ROMEO 1985 GTV-6 2.5 2.5L 6 Cyl. Fuel Injector MM 0280150105 ALFA ROMEO 1986 GTV-6 2.5 2.5L 6 Cyl. Fuel Injector MM 0280150105 ALFA ROMEO 1987 MILANO GOLD 2.5L 6 Cyl. Fuel Injector MM 0280150105 ALFA ROMEO 1988 MILANO GOLD 2.5L 6 Cyl. Fuel Injector MM 0280150105 ALFA ROMEO 1989 MILANO GOLD 2.5L 6 Cyl. Fuel Injector MM 0280150105 ALFA ROMEO 1987 MILANO PLATINUM 2.5L 6 Cyl. Fuel Injector MM 0280150105 ALFA ROMEO 1988 MILANO PLATINUM 2.5L 6 Cyl. Fuel Injector MM 0280150105 ALFA ROMEO 1987 MILANO SILVER 2.5L 6 Cyl. Fuel Injector MM 0280150105 ALFA ROMEO 1988 MILANO VERDE 3.0L 6 Cyl. Fuel Injector MM 0280150105 ALFA ROMEO 1989 MILANO VERDE 3.0L 6 Cyl. Fuel Injector MM 0280150105 ALFA ROMEO Alfa of 75 2.50 litres of 113-110 KW of 02.86-02.92 ALFA ROMEO 75 (162B): 2.5 V6 (162.B3) 2.5 V6 CAT 3.0 V6 (162.B6A) 3.0 V6 (162.B6A) CAT 90 (162) : 2.5 i.e. V6 (162.A, 162.AA) 2.5 i.e. V6 Alfa6 (119) : 2.5 i.e. (119.AA, 119.AB) GTV (116) : 6 2.5 (116.CA) LANDROVER RANGE ROVER I: 3.5 3.5 Vogue OPEL ASCONA B (81_, 86_, 87_, 88_): 2.0 E COMMODORE C (14_, 19_) : 2.5 E COMMODORE C Break (61) : 2.5 E KADETT C Coupé : 1.9 GT/E 2.0 E Rallye 2.0 GT/E MANTA B (58_, 59_) : 1.9 E 2.0 E MANTA B CC (53_, 55_) : 2.0 E MONZA A (22_) : 2.5 E 3.0 GSE REKORD E (17_-19_, 11_, 14_, 16_) : 2.0 E REKORD E Break (61_, 66_, 67_) : 2.0 E SENATOR A (29_) : 2.5 E 3.0 E ROVER 2000-3500 3/5 portes (SD1): 3500 Vitesse VAUXHALL ROYALE: 2.9 E 3.0 ROYALE Coupé : 2.9 3.0
DaveEFI
Re: Rover 3500 Vitesse injector dead times, 0280150105
Post by DaveEFI »
Flow rate I work to for the RV8 running factory fuel pressure of 36 psi is 173 cc/min. But could well have been wrong all these years. :D
spitnl
Post by spitnl »
Can't help it.
This is what the test produced.
The 30s 100% duty cycle and interpolating the other test results both gave 180cc/min
If you do a search on the injector number, the flow usually quoted is 191cc/min @43.5psi
Which converts to 173.8@36psi when you do the maths.
Maybe my fuel pressure runs at a slightly higher pressure.
LAV1000
Post by LAV1000 »
Lot of fabricators do spec there sensors whit heptane and not pump fuel :?
spitnl
Post by spitnl »
That doesn't change the flow in cc/min, N-Heptane flow in cc/min is the same as for petrol.
You are right that lbs/hr and g/min is different, due to the differences in density.
DaveEFI
Post by DaveEFI »
spitnl wrote:Can't help it.
Yes - I simply used the corrected figure found on the Stan Weiss site. But my fuel pressure was checked with a gauge and is correct.
spitnl
Post by spitnl »
Well, I tested my fuel pressure regulator, and it is 36psi.
So that's not the problem.
Then I flow tested 3 other injectors.
Results?
174-178-174 cc/min, checked several times.
So it's the injectors that caused the problem.
The dead times of the other injectors where within reading error.
DaveEFI
Post by DaveEFI »
The spec for the resistor pack is 6 ohms +/- 1 ohm. Injectors 2.4 ohms +/- 0.5 ohms at 20C. The total resistance of both and wiring given as 7-10 ohms. I'd guess that could give some variation of true dead time.
