Dear All
The history..
2008,Ripped all the components of a Ford Mondeo and re-planted them on a 1968 Lotus Elan Plus2 twincam , boy was that a steep learning curve, but successful , running Ms1
Update
2018 Have now sold on the Lotus ( with Dellortos re-fitted) and am in the process of ripping the donor parts off a 2.0 Ford Focus Zetec and transplanting the engine in a 1958 Morris Minor, running Ms1.
The question
The ISCV valve from the mondeo had a diode within its body ( and if one powered it the wrong way would destroy it ), I believe to prevent eddy currents etc ( it's been years since I did emf's etc. ) , but the donor Focus ISCV does not have this inbuilt ( as far as I can test ) and I can see no sign of it in the Ford Focus wiring diagram.
Have Ford altered the way they worked the ISCV ?
Is the diode still needed ?
So , should I fit a diode across the ISCV ? and where should I fit it ? Bearing in mind there is one 12V power lead from the Ms Relay board through the loom feeding both the ISCV and Injectors.
The options
Place it on the relay board 12v power feed to the Injectors and ISCV ?
How if at all would it affect the Injector operation?
Place it directly across the ISCV ?
Please help.
John
ISCV diode
- Running MSx/Extra
- Running MSx/Extra
Re: ISCV diode
Just found this which I suppose answers the question
"Put a 1N4001 diode across the PWM Idle valve itself - the banded end goes to the 12 Volt supply, the non-banded end goes to the lead that goes to your MegaSquirt® controller (this diode is for flyback purposes on the idle valve)."
John
John
Re: ISCV diode
Yes you need the diode.
Do consider upgrading to at least MS2. While it can still work, MS1 is pretty old and clunky now.
- Running MSx/Extra
Re: ISCV diode
So am I,so is the Morris Minor....you will be too .....one day.
John
P.S. I remember what a steep learning curve it was in 2008...and I'm not getting any younger.
John
Re: ISCV diode
Hahaha........ You young guys are too funny!
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
Re: ISCV diode
So you did master the MS1, you do understand the EFI principals.john.p.clegg wrote:James
John
Why not stepping up to MS2 ?
Youre mind is a free tool and exercise doesn't make you any dumber, maybe a headache.
And there is stil a great forum to support you.
