EDIS 4 coil.
Here is where you can discuss with other MegaSquirter's various automotive (but non-MegaSquirt) topics. Threads will be removed if they aren't posted to for 10 days.
EDIS 4 coil.
Postby DaveEFI » Fri Apr 07, 2017 1:49 am
Pal has had (we think) an EDIS4 coil fail. He's a long way off, so I've not seen it myself.
One cylinder of a pair appears not to be firing at all. Which sort of doesn't make sense to me. But swapping the coils - it's an eight cylinder - moves the fault too.
Any guesses what could cause this? The resistance readings of the coil seem normal at about 1 ohm primary, 30,000 ohms secondary.
DaveEFI
Re: EDIS 4 coil.
Postby billr » Fri Apr 07, 2017 7:48 am
One coil tower, or its approximate end of the secondary winding, could be shorted to ground. It may be a high resistance "short" that you would need a megger to find.
billr
Return to The Extra Pits
