Low-z injectors wanted
Here is where you can discuss with other MegaSquirter's various automotive (but non-MegaSquirt) topics. Threads will be removed if they aren't posted to for 10 days.
Postby jsmcortina » Sat Dec 02, 2017 4:57 pm
I'm after eight or more low-z injectors for testing. I'm not bothered about the flow rates. Standard 14mm Bosch style with EV1 would probably be easiest.
Anything in the UK?
Re: Low-z injectors wanted
Postby DaveEFI » Sun Dec 03, 2017 2:03 am
I'm just off out today, but should be able to sort you out a set of 8 from a flapper RV8.
DaveEFI
Postby jsmcortina » Sun Dec 03, 2017 1:28 pm
DaveEFI wrote:I'm just off out today, but should be able to sort you out a set of 8 from a flapper RV8.
Yes please.
Return to The Extra Pits
