rev limiter settings bug
(Runs on MS2 and Microsquirt)
elior77
Post by elior77 »
"Rev limit TPS bypass %"
The "help" suggest to use a value above 100 in order to disable this option, but when I try something above 100 it will ask to keep it <=100.
97 1.8T DIYPNP Seq Inj
http://megamiata.blogspot.co.il/
Re: rev limiter settings bug
I've adjusted the upper limit in the ini file for the next release.
elior77
Post by elior77 »
Can I do the same ?
dontz125
Post by dontz125 »
Yes. Make sure the project is not open is TS, then open the mainController.ini in your projectCfg folder using WordPad or something similar (for your sanity, DON'T use NotePad ...), and search for the following line:
Code: Select all
TpsBypassCLTRevlim = scalar, S16,   44,             "TPS %",    0.10000,   0.00000, 0,      100,         1 ; * (  2 bytes)
Change the 100 to something higher, like so:
Code: Select all
TpsBypassCLTRevlim = scalar, S16,   44,             "TPS %",    0.10000,   0.00000, 0,      200,         1 ; * (  2 bytes)
Open the project in TS, and set the bypass % to something over 100%.
elior77
Post by elior77 »
Great, thanks.
